Can anyone tell me what the factory tie rod end taper is for a 92-97 ball joint dana 60? Looking at buying tapered inserts and not sure which ones to get.
I bought some steel inserts from ruffstuff ^ specifically for these trucks and had my tie rod hole drilled out to accept a gm 1 ton tie rod. Works perfect.
Probably going to end up getting the ruff stuff tie rod kit but with an untapped drag link hole so I can ream that ro factory size and still run a factory drag link.
