Powerstroke Man 6.4
- Joined
- Jan 10, 2012
- Messages
- 4,039
- Reaction score
- 3
I went out to check codes on my 6.4 and AE won't pull enhanced codes or show any pids. Version 13.1
AE loads up normal click on enhanced power train,pulls the trucks vin finds all enhanced sensors. (All lights on the connector light up and ford enhanced bundle is activated.)
Check for dtc's AE scans all modules and only codes under generic powertrain banner comes up.
All the rest say "no codes received" even under the enhanced powertrain banner. (I know codes are present) dashdaq pulls and show pids just fine.
Go to look at any pids click on them and they only show "0"'s even battery voltage.
Also under the actuation tab if you try command something like VGTDC it will say "security access denied please check connection or reconnect to controller".
Tried to delete and reinstall and same problem.
Tried a different USB wire.
Re stared the PC
Run AE as admin.
Tried it on my other 6.4 and same problem.
Thanks in advance.
Re stared the PC
Run AE as admin.
Thanks in advance.
