Lets Talk Oils And Maintenance (Opinions Welcome)
Powerstroke Man 6.4
What kinds of oils you folks use for your truck or trucks? I recently got two free 5 gallons buckets of CAT DEO 15W40 CI4 oil and I have running that oil since. I usually go out and buy Mobil Delvac 15W40 CJ4 or Valvoline Premium Blue 15W40 CJ4 but I thought hey I got 10 gallons of Cat DEO CI4 for free why not try it out.
Thoughts on the Cat DEO CI4 15W40
Engine seems to run quieter with this oil then the other oils I have used in the past.
Less BB
Cooler oil temp
Bad
The exhaust is really strong.
I have read that since CI4 oil is a older oil and is meant to be ran in older engines it will cause more soot build up in the DPF if your truck is not deleted.
Any other cons that CI4 oil has on a 2007+ EPA engine?
I usually change my oil and filers 5-7K since I tow 10K+ almost everyday
What kinds of oil (type brand viscosity) do you buy?
How much miles do you put on that certain oil before you do a oil change and fuel filters?
Fuel filters
5-7K since where I live diesel contains a lot of water and the fuel is always dirty. loud injectors etc
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Keep in mind the filters only have 5-7K on them
I always run a additive (diesel kleen silver bottle, ford PM-22-A)
What fuel additives do you folks run or recommend?
Motorcraft oil filter and fuel filters
Thanks in advance
forcefed6.4ford
Medicine Hat... Again
Shell Rotella synthetic 5W40. Change every 3,000miles. Extreme service. I deal with tons of dust at work. OEM oil filters.
Fuel filters are Donaldson for my airdog. Changed every other oil change.
No additives. EVER.
Csilva187
15w-40 delo every 5k. fuel every 10k. Motorcraft filters. Trans service (LV and filter) every spring. Fuel additive if I get it free.
capt dong
Houston, TX
Racor oil filter every 5k miles. Oil change last time was with 10k miles. Blackstone was good. MC diesel 15w-40.
Used to use Racor fuel filters for factory fuel system but then I got an Airdog and have Donaldson and Baldwin filters on them. Drain once a month. New filters every 15k miles. Fuel bowl is filterless. Will delete.
PM22 in every tank.
Tow and haul at least twice a week.
Stroked777
Casper, Wyoming
Valvoline 5w40 syn. Engine is a lot quieter since I switched from conventional, but only reason I ran conventional is because when I work at a garage I could get it for free, nothing like a free $140 oil change and free filters LOL, fuel additive I use power service and I change fuel filters every other oil change
Kedstrokin
Moulton TX
I run motorcraft oil and filters. Change my fuel filters every oil change 5k run diesel Kleen every other tank or when I think about it.
Sit down shut up and hold on to your nipples.
tbsimmons
Bakersfield, CA
Racor Filters.
Fuel every 10,000.
Delo 15/40 between 3 and 5000. I beat on oil pretty hard though. Truck is used mostly for towing so when running oil temps can get in the 230 range.
fine69
Cranberry Twp,PA
I use Valvoline 5/40 synthetic with Motorcraft filters, change every 3000 miles. Motorcraft fuel filters every other oil change. Ford cetane boost every tank.
3brorce
Not to derail but to add to the thread where are most of you guys purchasing your racor/motorcraft filters from sunrise?
Radioflyer
Delo 15w40 or shell 15w40 year round w/motorcraft filter and wix fuel filter (fuel bowl delete and un-regulated return) every 5k.
bigbeanOBS
south jersey
Amsoil and ford oil filter and fuel filter no problems grease the front end check trans fluid change trans fluid once a year everything eles 5-7 k miles on amsoil
Sent from my iPhone fixing trucks
Powerstroke Man 6.4
I just started ordering oil and fuel filters from sunrise very fast shipping and beats the dealer/o'reilly's prices.
Fuel Filter
Dealer
$76.65
Sunrise
$55.19
Oreilly's
$80.99
Oil Filter
Dealer
$29.43
Sunrise
$21.19
Oreilly's
$26.99
Sunrise
so $55.19 + 21.19 = 76.38
Dealer
76.65 + 29.43 = 106.08
Oreilly's
80.99 + 26.99= 107.98
So I save
$29.7 if I order though sunrise then the dealer or $31.6 if I order though sunrise then oreilly's.
Its not a whole lot of savings but hey at least I don't need to drive to the dealer or oreillys and waste fuel to get them its just a click away LOL and 2 days since I live in Hawaii I don't mind the wait though free UPS shipping you cant beat that. .
