So I had recently developed a leak in the up pipes behind the collector. Big surprise, right?
Well, a 6-point socket was spinning on the collector bolts (probably from rust) so I decided to cut the manifold to up pipe bolts. Got the up pipes off/out. Well after and MAP gas torch, I can't punch ANY of the bolts out.
As anyone who has done this can attest there is little to no room to get to the bolts. (I have the down pipe removed.)
I need ideas. At this point I'll try a few more doses of hot wrench and PB Blaster, but if I have to do the manifolds I'll just pull the engine, since chances are there will be at least one stuck bolt there, too. I really don't want to go that, but eventually I'll need to install my new oil pan anyway.
