one piece, 4link, and bags
Oh-ate6.4PSD
Vicksburg,MS
First time at the track 4th pull killed my drive shaft and attempted to spit my blocks out. Who makes a 1 piece double cardan slip shaft or do i get custome made? Im lookin at 4 link pics and doin a airbag set up, im prolly gon go that route. Opinions welcome
co04cobra
WV
You need traction bars..
If you're going to keep that much rear block I'd call Trevor at PMF and have him send you a set of his custom traction blocks.
He can do the 4 link, blocks, and traction bars all in one shot for you.
Oh-ate6.4PSD
Vicksburg,MS
Hell yea it is. I told the wife, stock head bolts still holdin and my trans is still a bad mf so ill take some drive shaft carnage
Oh-ate6.4PSD
Vicksburg,MS
Im lookin at pmf's blocks and bars kit. if i can make a 4 link with bags for close to the same $ ill go with the bags. Still researchin rite now as i have a work truck so im not in a hurry
not an effing wonder LOL
block mount traction bars are your saving grace. yet another vote for PMF
yfz rock
Wow that's crazy I have had good luck so far my truck no traction bars and a block that big stack with 2inch blocks. Are you launching in 2wd or 4wd?
Oh-ate6.4PSD
Vicksburg,MS
3 times in 2wd by accident due to hub issues. then on the 4x4 launch found somebodys a/c slick spot, when she found traction again kabooooom floppy floppy
yfz rock
Oh ok be cause I have tried both 2wd and 4wd and 2wd was way slow to much spinning and hard shifts. 4wd strait beast mode I could not believe how fast my truck was shift were much better but I also launched at 25+psi
