Powerstroke Man 6.4
- Joined
- Jan 10, 2012
- Messages
- 4,039
- Reaction score
- 3
I need some help choosing a turbo setup for my truck. The truck is a 2008 Job 3 F-250 CCSB 262,000 miles. The turbos on the truck now are on the way out.. Making odd noises at idle no power odd noises at high boost. I tow 14K + daily up steep grades and was looking for a setup with towing in mind. Recently a hand full of "single turbo" threads have come up but I have rarley heard people talking about towing with a single . The +'s I've heard is
1. More room under the hood
2 Reliability
3 cheaper to rebuild
I got a couple questions
1.How does the billet 66 spool up while towing?
2. What would EGTs be like climbing a 6 mile 6% grade towing 14K+? ( I tow up this grade almost everyday) ( I know some of it depends on your right foot)
2. Cruising EGT temp? At 60 MPH 14K+ load flat ground with some rolling hills? And unloaded at 60 MPH flat ground?
3. Which would be a better choice 62/68/.91 or the 66/74/.91 for what I tow?
4. I've read that singles tend to have less EBP because no VGT and they tend to keep the engine alive a little longer less stress on the rods?
5. I know that singles tend to love the higher RPM than a compound setup. Will the single cause any more rocker arm damage than a compound setup because the truck will sustain higher RPMs for long periods of time while towing?
Elite torque tows
1.Will this setup exceed stock EBP #'s?
2 both turbo setups will require a no limit CAI correct?
All opinions/experiences welcome
Thanks in advance
2 Reliability
Elite torque tows
Thanks in advance
