Help help help codes no power please
TXlineman83
Austin, TX
So I got my truck from the shop. Fired up when I was there. No power. Several codes. Almost like limp mode.
U0115
There's a few more.
Powerstroke Man 6.4
U0115
There's a few more.
U0115 Lost Communication With ECM/PCM B I always get this code on my 6.4's. Just clear it should return to normal.
TXlineman83
Austin, TX
I think I figured out the problem. The shop let my batteries die and now I'm having issues. Truck won't even start bc batteries does in between changing tunes just now. Hopefully this will fix it when I go get new ones
TXlineman83
Austin, TX
New batteries no fix it. Seems I'm not much fuel through the LPFP. It will not drain anything when I open it up.
Csilva187
Have you drained it recently? Could be plugged up what I'm getting at I guess. Correct me if I'm wrong but I thought you could get an psi idea via fuel cooler Schrader valve? Codes?
TXlineman83
Austin, TX
Truck is running like ****. Excuse my lango. Doesn't seem like any power. Doesn't seem to have any throttle response.
TXlineman83
Austin, TX
Sorry for the horrible quality of the pic. That was cursing at 65mph
