Best setup to make 750-800Hp with a 6.4
300000 and counting
Ohio
Like it says I'm looking to make at least 750 HP but not over 800HP (My tranny is only good for 800hp), I tow a fair amount and DD about 800 miles a week so I'd like to have a setup that complements Towing and Daily Driving. I'm currently running a precision 71mm turbo from Rudy's, could I get to 750hp by adding a 59mm and 15% or possibly even 30% injectors to my current setup (plus dual fuelers and a lpfp)? Or do I need to bump up to a 59/76 setup with 15% or 30% injectors?
My current truck mods are as followed:
- 71mm Precision LP Turbo
- Warren Diesel Comp Plus Tranny
- No Limit Intake
- ARP head studs
- Elite's Wastegate kit (not installed yet)
- Better Push rods (I don't know anything about the though)
- Mini Maxx tuned by Gear Head
I know that I want to run a Midwest Dual Fueler kit and a Marty's fuel system, but I don't what combination/ brand of injectors and turbo's I need to get me to my goal. Any help will be appreciated
Shafer171
Michigan
Sounds like your on track to meet your goals, I am building the same setup right now with a 750 hp goal in mind
bigrpowr
<How I Fly
Administrator
You can easily get there , but you'll need a waste gate , a hp turbo , and 30% or bigger nozzles. You'll need up pipes at minimum , but the bd set is a ton of bang for the buck. Let me know if I can help !
StrokiNDieseL
Geneva, Fl.
WHS^, LPFS, ****** fuel bowl, all pipes upgraded also. I've done everything mentioned but wheel replacements instead of new chargers & yielded 704RWHP. But wish I would have done new chargers but thats soon.. All I need is a trans & its currently in getting one! I added 30's & had my injectors flow tested but I know I need dual fuelers asap! GL
Jonnydime
Dual fuelers 60% nozzles and a drop in 76mm turbo. Better yet pick the pair of High Power Jr's in the classifieds. Up pipes would be easy since you already have the turbos out.
like everyone said, get your dual fuelers from Morgan as well as have him put 60% nozzles on your injectors. you will need a 59mm hp turbo for sure. if you bump your atmo to a 75 or bigger, you will be knocking on 800
Somd_6.4
Elite 60hp nozzles stock/72 atmo and Morgan's dual pumps put me at 730-740 according to hp calculator
300000 and counting
Ohio
You guys don't think 60% would be to big? If Somd 6.4 is making 730hp on 15% surely 30% would be big enough to get me to 750hp
30s will likely get to 750 but why not have room to grow. price is basically no different.
Neither point you mention is a valid concern. Both will be addressed by tuning.
Rubenk
KCMO
You'll be very happy with a 76/59 turbo setup with 60% nozzles and dual fueler. I made ~713whp(track confirmed) with factory injectors, dragonfire, and RCD 75/59 turbos.
Tuning will be the crucial part in keeping it low smoke and responsive.
Black AOD
Ohio
- No Limit Intake
- ARP head studs
OP, I see your in Ohio. DM me, we can talk or even meet if you're close to me....
