Oil fill tank.
kingbrent1969
I was taking the oil fill tank off my p8 F250 6.4. While taking it off passenger side valve cover. I broke the small plastic line that connects to the bottom front of the tank. The plastic line goes back behind the coolant fan. I need a part number or a diagram of where this line goes.
Thanks Brent
Sent from my SAMSUNG-SM-G935A using Tapatalk
kingbrent1969
kingbrent1969
crankcase vent oil separator is what it's called I think any help be appreciated.
Lipka101
Maryland
Just get a piece of hose that fits over it and a couple hose clamps.
kingbrent1969
From what I can tell the line goes across the front of the engine. Is that correct? Just trying to figure out what all I have to take off to fix this junky plastic pipe.
6.4f350
The line goes down behind the alternator bracket and into the passenger side of the bed plate. It's a drain line from the separator back into the pan. No way to replace it without a lot of work, I just replaced mine with a rubber line.
