Alberta 6.4 build
powerstroked08
Pennsylvania
:whs: I have the X's and they spool great(mind you its a 6 speed so its a lot harder to spool than an auto) But my next set would be high powers. Reasons why is the stock housing on the tow x hp(59) is a restriction and limits the flow. And the spool up is the same as the high powers. So there is a greater power potential with no sacrifice in lag( not enought to speak of anyhow) So one day I'll change mine up for these reasons.
Wastegate
Alberta Canada
But with thirty below air temps for 75% of the year should be more dense air to aid it spool eh? Hah
Subbed looks like a real fun truck!
B585Ford
WV
What's the baro (elevation) there????...that would be a bigger factor than the cold temps in regards to spool up....EGTs yeah the cold will definitely help that.
Wastegate
Alberta Canada
In edson elevation is 3035 ft, maryland is at 3356 irc for comparison.
current baro in edmonton is 101.2 kpa (14.6 psi) with a humidity of 85% so pretty damn close to sea level atm
SlowSmoke
Sylvan Lake, AB
I agree. Temp won't have anything to do with spooling, pressure will. On the plus side when it's below zero (Canadian thermometer eh) you get less detonation on your pistons with all that ice cold dense air!
compoundturbo373
im really thinking the single maybe start off with billet 66 with a good tune see how i like it save me some $$$ for dual pumps
compoundturbo373
Wastegate
Alberta Canada
Totally agree, Atmospheric intercooling. just gotta look at the positives haha
Im in the same boat as you! Gonna have to see how drop ins stack up to a single head to head haha. Truck looks good, 4inch lift?
low 700's
you will have plenty of fuel to support a bigger charger tho.
powerstroked08
Pennsylvania
Should spool well. I think they spool better than a cast 66 but you would have to confirm that with somebody like morgan or craig.
