Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-13-2012, 09:06 PM
ToMang07's Avatar
ToMang07 ToMang07 is online now
General
Member's Gallery
Default BW S366 Turbo Specs?
Anyone have a full spec list for the S366?
Curious whats the max HP you can comfortably push with it.
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, Hydra, 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, T500, FRx, COMP 910s, Fisher 8' MM2, 5" AL 1-piece Drive Shaft, Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203* TS and Billet Housing, ELC, Fumoto, Leveled, Airlift Bags, 16x10" on 35s, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing... Rebuilt Transmission at 137k~AE w/Ford Pack~
  #2
Old 02-13-2012, 09:17 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
General
Member's Gallery
Default
I dont know for sure, but I drove a truck with one in it this weekend.
My only concern is Back Pressure!!!
This is a 5 speed truck but it boosted WAY too quick to be having normal drive pressures.
I believe the owner is going to throw a back pressure gauge on it very soon so...
__________________
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH ******,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/******** tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
Honey Badger HPOP
Powerstroke Injectors
  #3
Old 02-13-2012, 09:20 PM
ToMang07's Avatar
General
Member's Gallery
Default
The reason I ask is I would like to buy the turbo now when I have the money..but as of right now I have the $$$$$ for the turbo and kit.
S366...easy....S471...a few bills short.
__________________
  #4
Old 02-13-2012, 09:23 PM
CSIPSD's Avatar
General
Member's Gallery
Default
Its a much smaller turbo then I thought it would be, my modded H2e looks HUGE next to it.
__________________
Joe
Honey Badger HPOP
  #5
Old 02-13-2012, 09:27 PM
ToMang07's Avatar
General
Member's Gallery
Default
Quote:
Well, I'm hoping to get my grimy hands on some 250/200's in a year or so... and I don't want to have to worry about buying a turbo, too, if ya know what I mean.
__________________
  #6
Old 02-13-2012, 10:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
Major
Member's Gallery
Default
the turbine wheel is 80mm inducer, 74mm exducer, the standard turbine housing is a t4 .91 divided housing. The turbo matches perfectly with a 500hp setup which i am running, however joe is right. the responsive and awesome street manners come at a price of backpressure on the top end. I am running a wastegate and you can defanitely hear it open through the exhaust. I would NOT run one on a 450+hp setup without a wastegate and consider the turbo to be reliable (with that housing). I used to run my backpressure gauge way off the damn 60# gauge while boost was only 35ish. Once i got the gate tuned, i am around 40psi boost with 45psi or so BP.
I think with the 550-600hp those 250/200 injectors are capable of (with proper air flow, which this 66 wont likely give you) you should be looking at a bigger turbo.
  #7
Old 02-13-2012, 10:07 PM
ToMang07's Avatar
General
Member's Gallery
Default
Thanks. That's kinda what I was worried about. So it would work until I got the injectors,but then I'd need a bigger turbo. Ugh.
__________________
  #8
Old 02-13-2012, 10:09 PM
CSIPSD's Avatar
General
Member's Gallery
Default
Good info... I was impressed with how quickly it lit, but I knew the back pressures had to be up there.
__________________
Joe
Honey Badger HPOP
  #9
Old 02-13-2012, 10:49 PM
JHILL's Avatar
JHILL JHILL is offline
Sergeant
Member's Gallery
Default
IIRC on Jakes truck, '02 auto,s366, stock injectors @ 35psi the scanner showed
50ish psi or 1:1.
Joe what size modded h2e are you running?
The 66mm HX50 on my truck holds 1:1 at 42-42 psi I have a 19cm housing though
what injectors are in Joe's truck? Sureflows IIRC
__________________
E '99 F-350 CC LB, ZF6, IDP -T4 mount, Reg. Return, Comp. Fuel System, Comp Valve Springs, Melling LPOP, DI P-Rods, Adrenaline HPOP , ARP's, Detroit Tru Trac,
S468, 250/200, Tyrant tunes
http://www.iratedieselperformance.com/
  #10
Old 02-14-2012, 12:37 AM
Dieselboy.'s Avatar
Dieselboy. Dieselboy. is offline
Major
Member's Gallery
Default
I run an s471, I literally just did a few burns, and WOT I saw 46-54
__________________
Race Truck - 2002 F-350XL RC/LB
11.79@113.27
RIP - 2000 F-250XLT 2WD EC/SB
70 F250 swap build in progress
New daily - 2011 F-350Lariat CC/LB
Bolt ons
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
