Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-16-2012, 02:41 PM
KEM Performance's Avatar
KEM Performance KEM Performance is offline
Sponsor
Member's Gallery
Default FICM Shootout - Tuned, 48V, and 58V
A lot of customers have been asking what the benefits and gains are of the different FICM options for a 6.0L, well... thanks to Tom and Dan at the Powerstroke Connection, we have dyno plots to share. Dan lent us his 2004 6.0L truck for use in the testing. He has a fair amount of mods and is running our KEM race tune. Tom provided us his DynoJet (non Eddy current) dyno for the test. We set out to see what the gains/numbers were for the following:
Stock 48V FICM
KEM Custom Tuned Stage 1 48V FICM
Swamps 58V FICM
KEM Custom Tuned Stage 1 Swamps 58V FICM
The FICM calibration used was ARZ2AH10 which is an Inductive heat calibration. The test was run with the same truck, same dyno, and on the same day, no trying to compare different vehicles in different configurations. The FICM swap was done on the dyno, no unstrapping.
Now for the results!
First test - Swamps 58V versus a 48V FICM both flashed with ARZ2AH10.
Below 2750 RPM, the Swamps 58V FICM has more power and torque, above they are identical in power.
Second Test - KEM Stage 1 Tuned 48v FICM versus a stock 48v FICM.
A 43RWHP max gain with a max torque gain of 137 to the tires!
Third Test - KEM Stage 1 Tuned 58v Swamps FICM versus a stock 58v Swamps FICM.
Since the Swamps 58V FICM started higher than the 48V FICM, the max gains when tuned were slightly lower at 41RWHP and a torque gain of 112!
All of these runs were done on a non loading dyno. If testing were to have taken place on an Eddy current dyno, numbers would have been higher.
The custom FICM tuning not only benefits those stock injector trucks with added power, but also can eliminate some drivability issue associated with trucks that have larger injectors(we make the files to your truck specifics).
Presently to get your FICM tuned, it needs to be sent to us for a bench flash. In the very near future, we will be releasing our all in one flash tuner! It will flash not only the PCM and the TCM but will also flash the FICM with our custom tunes! This tuner will also function as a monitoring display device with a suction cup windshield mount. More information to follow.
Mike
__________________
Custom tuning of Powerstrokes since 1996! From the 7.3L to the all new 6.7L, we custom tune them all.
  #2
Old 02-16-2012, 02:44 PM
Pizza pig Pizza pig is offline
Member's Gallery
Default
Good stuff Mike, thanks for sharing ARZ2AH10 is the latest ficm calibration correct?
  #3
Old 02-16-2012, 02:45 PM
faster6.0's Avatar
faster6.0 faster6.0 is offline
Member's Gallery
Default
Sweet!
  #4
Old 02-16-2012, 03:01 PM
Snake's Avatar
Snake Snake is offline
Colonel
Member's Gallery
Default
This is by far the best information I've seen on tuned FICM's. Thanks for taking the time to test and share the results.
Just went back and took another look at the sheets........what a difference in torque between 2,000 and 2,500 rpms on the second graph!
__________________
TRUCKLESS
BULLETPROOF DIESEL
www.bulletproofdiesel.com
Biofuels Technologies
1A Auto www.1aauto.com
  #5
Old 02-16-2012, 03:09 PM
Sponsor
Member's Gallery
Default
Quote:
No, ARZ2AH11 is the latest ( For a 2003 engine) but the difference between the two is with the inductive heat shut off temp which I change anyway.
Mike
__________________
  #6
Old 02-16-2012, 03:18 PM
Rmartin-97's Avatar
Rmartin-97 Rmartin-97 is offline
Major
Member's Gallery
Default
Whats the prices on this?
__________________
2009 f250
http://www.unlimiteddiesel.com/
  #7
Old 02-16-2012, 03:45 PM
smokinstroker's Avatar
smokinstroker smokinstroker is online now
Colonel
Member's Gallery
Default
the KEM ficm flash was one of my favorite mods, and i have ran all 3 different ficms available.
the power is just awesome, if a graph doesnt show it, drive a truck with one, it sold me instantly.
mike was also a great guy to deal with, plenty of time for you no matter how many questions you have.
  #8
Old 02-16-2012, 03:53 PM
golfer golfer is offline
Major
Member's Gallery
Default
thanks Mike~
looks like our 58 volt unit added the 40 or so hp down low and midrange...and your tuning made the difference above 2500rpm, where the ECM was shortening up the inj PW.
very well done...
  #9
Old 02-16-2012, 04:11 PM
sickslow's Avatar
sickslow sickslow is offline
Sergeant
Member's Gallery
Default
WOW!
__________________
05 ccsb, sct sf3 canned tunes , 4" exhaust, edge cts for monitoring, Sinister bypass coolant filter, sinister egr ******, 6.4 banjo's, blue spring, new oil cooler, freshly cleaned turbo, afe pro dry s drop in filter, zerex zxed-1 ELC, Valvoline Premium Blue, zoodad mod, 35x12.5 nitto trail grapplers, pro comp 8101 wheels, home made Harley headlights
  #10
Old 02-16-2012, 04:38 PM
PowerStroke Connection PowerStroke Connection is offline
Sponsor
Member's Gallery
Default
This was definitely a fun test. Although I have to say from running KEM's FICM tunes for quite some time, we knew they were much better but the results were very surprising!! Thanks Mike! It was a blast!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
