Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-24-2013, 09:39 PM
earlybroncoboy's Avatar
earlybroncoboy earlybroncoboy is offline
Sergeant
Member's Gallery
Default slave cylinder upgrade
hey guys can't seem to locate a heavy duty slave for my truck. what you guys running? got a 3850 plate. the only thing i could find was something about an idi slave being an upgrade. i don't see any difference in them.
__________________
96 f250 eclb 300k, P.I.S. 300/200's, BW s467.7, valair sintered iron dual,(parting out to fund engine build)
96 f250 rclb dana 60 swap,on 28" toyo proxes Unlimted 350/400s, My headers, Upipes and e-fuel, s468 (for now), pcs controller and firepunk trans, on 2nd stock bottom end
e99 F250 daily.... bone stock
  #2
Old 02-24-2013, 09:47 PM
Magnum PD's Avatar
Magnum PD Magnum PD is online now
General
Member's Gallery
Default
Napa cylinder? What I used.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #3
Old 02-24-2013, 10:07 PM
Sergeant
Member's Gallery
Default
i don't have an original in mine. its a advance one. i didn't know if they made a heavy duty. thanks
__________________
  #4
Old 02-24-2013, 10:08 PM
co04cobra's Avatar
co04cobra co04cobra is offline
Sponsor
Member's Gallery
Default
I just installed a complete pre-bled unit from federated. All aluminium and was bigger in diameter then the one I pulled out.
__________________
00 cc/sb zf6 F250- Some stuff done always more to do-Fuel 300/200s Air-Garrett 68/94-Oil SRP 1-Airdog to Fuellab
97 cc/sb- zf-5- Work in progress. PMF rsk w/ SD axles. 66 turbo, E fuel, 230/100s. SB DD clutch.
08 cc/sb - Elite bottom end - 2 fuelers, 59vgt/78atmo, Midwest 100% nozzles and coated heads etc....
www.teddavisautos.com
Many parts available for super duty trucks PM me.
  #5
Old 02-25-2013, 12:17 PM
bad12jr's Avatar
bad12jr bad12jr is offline
Major
Member's Gallery
Default
One for I believe an 88 or so idi is what's in my obs. It has a bleeder and is bigger. I blew 3 of the small non bleeder ones. Actually cheaper then the small one. Got it at Autozone.
Sent from my x2 chillin in the middle of no where
__________________
1996 F250 211000 on the clock
5spd XL
6637, SD Electric Fuel, 3'' DP to 5'' Tailpipe, Pyro, Boost and Oil Psi,
140cc AD SD injectors, T500 HPOP and ******** Tunes. Traction Bars.
300hp 500ft/lbs torque
2002 F250 sport sclb 144000 miles
BTS, 160cc stage 1's, studs, billet rods, banks ic, adrenaline Hpop, RR,
Van Turbo w/ ATS housing, AFE stage 2, 5" Turbo back, ******** tunes
15.27 @ 85mph
  #6
Old 02-25-2013, 06:37 PM
Sergeant
Member's Gallery
Default
thanks guys mine is aluminum so i might be alright i looked at an idi one at advance it looks the same to me lol. different part number though.
__________________
  #7
Old 02-25-2013, 09:14 PM
pontiacross's Avatar
pontiacross pontiacross is offline
Sergeant
Member's Gallery
Default
I'm running one out of a early 90s idi too
and a bronco master cylinder
__________________
Ross
2.6 modified street pulling truck "The Lone Stroke " 2011 season video!
sold
-97 f350cc soon to be dually . swamped
-03 f250 2wd 7.3 6 speed (sons truck)
-95 f350cc dually 2wd 460
  #8
Old 02-26-2013, 04:30 PM
bad12jr's Avatar
Major
Member's Gallery
Default
Pontiac is where I found the slave information in an old thread. Thanks btw.
__________________
5spd XL
15.27 @ 85mph
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
