BS Hauler
Have you checked actual fuel pressure ? Sounds like it could be fuel starvation.
My brother and I were just discussing this last night. Going to put my mechanical Guage on the regulated return test port and see what happens. Thx for suggesting it. Wondering if my AirDog draw straw is too tight to bottom of the tank. Will report back on findings. Might not get to it till Friday with my schedule this week.Have you checked actual fuel pressure ? Sounds like it could be fuel starvation.
Just did stand pipe and HPO Rail nipple O-rings as I suspected HPO leak when we changed injectors, but don't feel there's a large enough differential between desired and actual to go crazy. Going to pull injectors Friday and see what we find, have a feeling cylinder 5 will have no carbon on the nozzle. I did Warren's total upgrade (new solenoids and spool valves) and am half wondering if they have issues as seen reports of some while doing research on my issues.Air pressure test with the passenger side valve cover off might reveal a small HPO leak.
I will check those out Friday and get back to u. I have heard that these injectors won't idle correctly without proper tuning so I even got tunes from WDI and that didn't help either.can you monitor mass fuel desired, inj PW, boost, engine rpm and ICP? (full load, driving WFO)
stock tune (ie, no tuner on ECM) still acts the same?
seems to me that the tune simply isn't requesting any fuel (and/or the injs aren't capable/or are damaged in some way)
Sorry didn't attach first time.This is cruising about 35mph.
This is then pedal to the floor and ever so slowly increasing speed.![]()
It is a tow file that's loaded so would the pw be normal?I was hoping for an actual 'datalog' of those parameters, not so much a screen shot...but
injector PW looks quite short for a 'race tune', even though there is (apparently) plenty of ICP (@3300psi based on 4.4v)
...also 1 and 3 blew the copper ring and have combustion carbon up to the bottom fuel o-ring. Cylinder 7 looks like it was starting to go. Is it possible that the cups are damaged?
Yeah batteries weren't happy with so many starts and short run cycles. They've been put on the charger while injectors are out.Your battery voltage seems pretty low to me.
