6.4 Gone. 2017 6.7 F350 Platinum In.
Black AOD
Ohio
Reverse level got done and looks much better. Rides a lot better too. Got the wrong U-bolts, need to get some different ones but we found some that will work for now.
Need to figure out some shock upgrades now.
Sweet!!!!! It’s crazy how loosing a block that doesn’t mess with the ride technically, makes it ride that much better.. you need 2.5 resi shocks in your life!
Black AOD
Ohio
Yeah I think King or OUO/Radflo shocks are going to happen eventually
Black AOD
Ohio
Well decided on 4800# front coils. Think I made the right choice. So far it's about an 1.25" drop. I figured it will settle another 1/4" probably. Rides way better. Gained some rear rake again which makes me happy. Had to trim front bump stops down as well. Took 1.25" out for now.
Got some shots of it next to this stock height silver 17 Platinum truck. It's actually Drew from D&Js truck.
looks good. any chance you can post a straight on side pic of your truck in the same spot you did when before the spring change? iirc it was in a loading dock or something...
Black AOD
Ohio
Ill try to next time I'm at FirePunk, that was outside their front shop door
Black AOD
Ohio
have any pictures of clearance between bumpstop and axle?
I can get some. I cut about 1.25" out of the factory bumpstops. I could have cut another inch out but so far I don't see the need, I haven't bottomed out yet and I'm still on stock shocks. So I'll continue to monitor over time to see if more needs taken out.
Black AOD
Ohio
Here's mine currently. Driver and passenger side.
Black AOD
Ohio
Here is my brothers bone stock 6.7 f250 Lariat Ultimate 17 bump stop clearance (for comparison) It looks like it has a bit more room than mine but not much.
