P0087
Florida
Just finished 500 mile break in on fresh KKD steel piston long block. KC Stage 2 low pressure turbo, 25 over injectors, running a break in tune. New AirDog 2 5G lift pump with RCD fuel bowl delete regulated return.
I’ve have several issues maintaining the same pressure at the return gauge.
While driving at 60 mph I felt a little slow down and looked at my Mini Maxx V1 and noticed the FRP had dropped to 1.8. Then I hit the throttle and it went back up to 10.7.
I pulled over and checked the gauge at the return and it was down at 3psi. I turned it up to 7.5psi and cleared the code and drove some more. It happened again and I pulled over. I readjusted the pressures at both the regulator and pump to read 8psi at the gauge. Drove another 115 miles without issue and then it dropped to 1.8 and spiked up to 22.5 all within a second.
Anyone have any ideas? The HPFP was replaced under a year ago. The HPFP gasket is motorcraft as well as the sensor but not the injector harness.
I have injector knock at low RPMS but not idle and my tuner said it’s normal.
I haven’t been able to catch and abnormalities with my Autel watching live data.
Any help is appreciated.
DEEZUZ
NO PUKESTERS
NWI
Im basically at a point to say that there are no good reman 6.4 hpfps. I've put 2 or 3 in before I got a good one. Same issue as described.
Some of them I was in there resealing the motor and up sold a hpfp just because we were there, only to end up putting their pump back in by the truck had an issue after a new hpfp was installed.
DEEZUZ
NO PUKESTERS
NWI
I believe these pumps nor solenoids can be tested via a bench. And I don't think they re making new OEM quality valves. COVID we were getting them with loose vcv and pcvs...
In a few years all the 6.4s will be gone and swapped. Nobody wants to work on these and I don't blame them. Even I'm starting to turn them away due to untrustworthy parts and support.
DEEZUZ
NO PUKESTERS
NWI
There was one place advertising brand new OEM pumps but my company wouldn't buy them. So instead I'll throw junk pumps in and warranty them over and over. I'm hourly, so I don't care.
Florida
I just put $45,000 into this truck without labor cost and the pressure control valve started acting up. It hasn’t even made it to the high power tune yet. And now I’ve got to jump through hoops for a warranty replacement and buy the replacement pump and wait for “testing” to confirm the issue before refund.
Definitely not happy.
Racer71
I’ve got twins on my truck, both through ford but reman by caterpillar in Franklin Indiana, not the cat big engine company. I bought both through my local dealer. I’m on 120 over sticks though. I hear a touch of injector noise at spots on one of my tunes, not happy with any of the tunes I have, most aren’t familiar or have never tuned like my setup. One guy on the hptuners board sold me some tunes, engine tune was awful but trans was good, wouldn’t respond to any requests for touch up or unlock them and let me fix a few things or use the trans tune with the engine tune that on truck.
Florida
I’ve got my second hpfp coming and am currently running a tune that allows my truck to run on 25 overs with only one pump.
I was running an RCD fuel bowl delete but it was letting air into the HPFP system so put the stock fuel bowl back on.
I know someone that tunes and doesn’t mind making adjustments. He’s going to be writing me a new tune after I get the second pump installed.
