1992-2009 F-series Super Bright CREE LED Reverse Bulbs
retrosolutions
Sponsor
Super Bright CREE LED reverse bulbs specifically fitting 92-09 Ford Trucks!
*Note: may exclude some models with different fixtures/sockets (other fitments available)
only $39.99 /pr!!!
NEW VERSION with UNLIMITED RUN TIME, full TEMPERATURE COMPENSATION
To place an immediate order, CLICK HERE
- 3x CREE's latest generation X-Lamp series technology
- very wide and bright distribution
- bright and uniform light spread
- self compensating for unlimited run time
- Fits stock location, just pop it in
- Designed, Made, and Manufactured in the USA
- Works in any 8-18v vehicle/socket
- 1 Year Warranty
Currently $39.99 per pair!
Each bulb consists of a 3 LED array using CREE's latest generation X-Lamp series. These LEDs pack a very big punch in a very small package, with excellent luminous efficiency, and amazing advancement in thermal transfer.
Each bulb totals more than 875 Lumen of directed light output at maximum output. That's more than twice the output of the stock bulb they replace, with all the produced light is directed rearward for optimal performance.
Operation time of this bulb version is now unlimited with self compensating temperature control, allows for maximum performance with long-term reliability.
The bulbs are designed, produced, and manufactured in the USA
Now only $39.99 /pr!!!
No reproduction, re-posting, or copying of images, text, or other media allowed without contractual permission
Retro-Solutions, LLC 2013 All Rights Reserved
retrosolutions
Sponsor
Here is a customer's Ram truck for example:
New CREE vs. Stock
New CREE
retrosolutions
Sponsor
All orders shipped, and production is finally up to levels allowing for stock on hand now!
retrosolutions
Sponsor
That's awesome! How do these compare to the old cree bulbs?
The biggest difference with the new version is they can be run indefinitely without heat damage to themselves as they are temperature compensated. When on for normal reverse use they are all-around brighter, and at typical running time equal in measured forward output, only at extended run time are they less in forward intensity. They are much more uniform for distribution over the width of output.
In relative intensity measurement, compared to the previous version the following data helps put it visually. (green is new 9W version with red showing maximum when driven to edge of CREE's absolute maximum ratings at the same temperature, blue is older version bulbs with the additional radial LEDs)
JD3020
Farmersville/Dayton, Oh
LED on the left, stock on the right. Pretty sure i can see better going backwards than i can forwards now. LOL Huge difference in light output.
retrosolutions
Sponsor
All orders for these are shipped, again thank all for your recent orders an enjoy!
retrosolutions
Sponsor
current production is delayed, existing and coming orders to ship tomorrow to latest of Monday at this time.
Thank you for the orders!
