2017 Turbo parts
FordTechChase
Oklahoma
Turbo on my dad's 2012 took a dump so I am looking for a price on the parts to do the 2017 swap on his truck. Shipping address will be a business in 74401.
I think the required parts are...
Turbo
Pedestal
heat shield on turbo
rh inlet pipe
downpipe, can't tell if both pieces are included in the 15+my illustrations online
turbo mounting/gasket kit
inlet pipe/down pipe clamps if not included in the gasket kit like the older trucks
lower intake manifold assembly
coolant return line
egr cooler pipe oring
I believe this is everything but may have missed some small stuff I can pick up locally if I did. Thanks Chase
only the upper part of the downpipe is required. you will need the passenger side exhaust manifold (will also need studs for up pipe end). also the plastic tube that connects the turbo inlet to the lower intake manifold. Many other associated gaskets arent listed either...
FordTechChase
Oklahoma
RH manifold isn't needed, did for get the rubber between the lower and the turbo. I have a all the upper gaskets in the tool box. The turbo gasket kit/mount kit on the older trucks included everything so I'd assume it includes the gaskets/clamps for the turbo on the 15+ aswell.
