Adding power driver’s seat
Strokersace
Towanda, KS
Has any installed factory power seat into a manual seat truck?
The 2014 I bought a while back is a loaded XL, but has a manual seats. Doesn’t bother me one bit, but my 5’1” wife has a heck of a time driving it. I bought a power drivers seat out of an XLT truck that I’m going to install. Identical with the exception of the power lower section. The plugs are different but I haven’t looked close enough to see how.
Is the wiring already there from the fuse box? Should just be an additional power and ground (I think). Or will I need to tap fused power from somewhere and run my own wiring? Looking to tackle this project this weekend...
Strokersace
Towanda, KS
Figured it out. Found a wiring diagram for the 6-way power seats. From there I was able to find the connectors, pin locations, etc. Fuse and hot lead into cab were there. Cab harness that plugged into C210 connector above park brake assembly didn’t have the wire. Had some correct spare pins so I added it and ran wire in factory loom to seat plug, then pinned it and the ground there.
Worked like a champ and factory connections to boot.
