building traction bars
compromised
Zeeland MI
Just wondering what people think about building there own bars. I have a crew cab shortbox and was wondering if i should follow the angle of the drive shaft from the rear end to the transfercase or follow it from the rear end to the split in the shaft????
Dzchey21
wyoming
i built my own, follow the shaft angle from the carrier bearing to the rear diff
BlueWaffle
Grapevine, TX
I built mine...theyre in that same thread. I also have a build thread over on the other site I'll see if I can dig up
dirtboy25
Ft. Scott, Kansas
LOL That reminds me of somebody on here. 600hp and ~1" bars. They turned into a "U" shape after the first launch.
2" DOM 3/16-1/4" wall thickness is the way to go. DOM is seamless and very strong stuff. Most other mild steel tubing, if you look closely in the inside, you'll see a seam. That seam is usually the first part to come apart when flexing alot.
RNicol
Milford Center, Ohio
I built mine from 2in square tubing 3/16 thick. I cut them at 7 1/2 feet and welded adjustable top links in each end. Front brackets were pretty simple to make with some angle and some 1/4 in flat steel. Rear brackets i used some C channel with 1/4 in ears with holes in them, welded the ears to the C channel and welded the C channel to the axle.. Thought the square look would look good and i like it. Let me know what ya think :ford:
