2016 FX4, CCSB, door sticker says 5600 on the front axle. Measuring from the tire to the wheel well a little under 9" in the front and 10 in the back. I have read the 4400 thread and several other on here on lowering. It seems the drop with 4400 spring is 1.5 to 2". I plan on pulling the block out of the back, that would drop almost 2" and then the tire to fender would be 8". With some of the other threads it seems there are several hitting the bump stop early and reduces the options for shocks. Would 4800 springs drop my an inch up front? This would make it level if I took the blocks out back and give me about 1 - 1.5" more clearance overall, which is the goal (for parking).
