Elite dual fueler pully
thuglike
Linden, NJ
So I snapped my dual fueler belt. No biggie I think NAPA has direct replacements. My question...can I get bearings for the pullys? One spins freely and the other seems seized. She won't turn at all. Is it easier to just get replacements or swap out the bearings on the ones there? AND.....which bearings and where can I get them?
Thanks in advance
co04cobra
WV
They are stock idlers iirc. Id get a new one through ford. Check really good that your pump pulley didn’t touch the mounting bracket. I need to source a actual elite sized K16 pump pulley. I made a sadp work but it’s undriving the pump slightly. Like to put the right one back on.
White_monster
The great white north
The elite duel fueler pump brackets always broke, think I broke 3 until I made a fix. The bearing number is on the seal. Take the pulley to a bearing shop and they can measure up and order you replacements. The pulleys in elites kit are not oem either. It'll be a couple weeks until I'm home to look at the numbers.
