fuel psi question?
01 blue 7.3
illinois
Today while I was driving I noticed my fuel gauge was boucing between 60 and 72. What could cause that?
01 blue 7.3
illinois
Well the gauge has a sending unit into the fuel filter housing. The only extra mod I have is the crappy edge. The temp is about 15 degrees and not sure of the wind chill.
4cstr
aberdeen, sd
Wind chill doesn't matter...but the 15 degrees does. If you are not running winter blended diesel...you may be in trouble. Get some diesel911 in there...plus if you are beginning to gell, you may need to change out the fuel filter. If the wax plugs the filter...the diesel911 won't help. Trust me on that.
4cstr
aberdeen, sd
With it being bio I would for sure then add in some 911 and change filters. I would also make it a ritual during the winter to dump in Powerservice with each fill. I love bio but it can be a bugger during the winter.
