Lowered Trucks
12FlowerStroke
I will be pulling the leveling kit off my truck and running no rear block and maybe softer front springs. My question is what size ubolts are needed for no block and what springs do I need to get for it to sit level? Going to be running 305/50/R20 12 wides -44. If anybody has pictures pleases post them. Thanks
bigrpowr
<How I Fly
sounds like you'll be running my exact setup .
O4ep3civ
Mike do you have anymore pictures?
powerstrokecrzy
Hickory, NC
I'd like to see some level side shots and pics of clearance underneath pics.
How did you lower the front? Softer springs or what? What size tire you running?
MorganM
SE Houston
This is lowered 3" front and about 4.5" rear. I've since raised the front .5" and am using a stiffer spring to avoid frame/axle interference. The rear is a DJM shackle and removed spacer.
Tires are 305/55/20
MorganM
SE Houston
Scott at Deaver sent me both pairs. Coil Spring Specialties made them. You can save $ contacting CSS yourself but Deaver is WAY easier to work with...
MorganM
SE Houston
Less than $350, but that was nearly 3 years ago. He helped me get shorter front and rear Bilsteins too. In hindsight, I wouldn't go lower than 2 or 2.25". I'd increase the spring rate maybe 8% instead of 15% and I'd go with Fox shocks.
Platinum15
Sulphur springs
Sweet, I was wanting to do about a 2/4 because Im running 24" alcoa on 295/40/24's. Fox is what I was leaning towards but didnt know how to go about getting custom one built.
