Should 22x12s fit under 2" leveling kit?
spooledplatinum
Kinston, NC
Hi guys,
Im a new member...so maybe i dont know the best way about going about this. But im wondering if anyone has any experience with putting 22x12s on a truck that only has a leveling kit. Im running 35 toyos right now but im think about the nitto 420s if i go with a deep dish rim. I thought about 20x12s but really love the look of a 22 since the rim is so offset. Does any one know which way to point me? Thanks!
WHY NOT
Carlyle IL
What year is the truck, what offset is on the 22x12's? I would guess its a -44 but may be different. But you will most likely have to do some trimming
BSB
Wondering the same thing. I would like to run a set of 20x12 -44 or -51, on a 2,5" level on a 2012. I would like to run a 33" tire if possible like a nitto 420 type is it possible?
South Florida
Thats very doable. Let me know if you want to setup a complete package on that or need any of the parts. I can setup the Leveling Kit, Wheels, Tires, etc.
BSB
Already got the level but will be looking for a rim/tire setup. Currently I've got 20x10 -24 with 305/55/R20 and get some rub. That's why I'm sketchy about 22's but maybe the more offset will help. Just really don't want to lift the truck but don't want to spend money on a setup and find out it needs major alterations.
UNBROKEN
Wheel diameter means absolutely nothing...tire diameter does.
And the -44 vs -24 offset on a 2"'wider wheel is only gonna make things worse.
South Florida
I have 305/40/22 on 22x12 on my Reg Cab that is actually slightly lowered in the front and have zero zero zero rub. Granted the tire size is pretty small but 33s on a leveling kit with 22x12 and some minor trimming is very doable.
SVTDiesel
Massachusetts
Here is an 08 F250 with no leveling kit or trimming with 325/50/22.
spooledplatinum
Kinston, NC
Got it to fit with some minor trimming. Already was looking at a set of used rims and tires. Thanks alot guys!!
spooledplatinum
Kinston, NC
This is the set up I decided to go with. I traded for these forces a couple weekends ago.
SVTDiesel
Massachusetts
You don't have to believe me, I have been doing this for years. Like on an 04 running a 305/55/20 on a stock height F350 Diesel with no rubbing.
SVTDiesel
Massachusetts
I have a 16 now, I was not aware of the differences until I tried it. None too happy now. I assumed going back to a 350 I could get away with the same, but I cannot without leveling it.
