Wiring gremlin please help!
95-F-2FITTY
arkansas
I have swapped the dash and harness out of a 96 PSD Into my 95. Everything works as should except for my wipers. When I turn my key to the "start" position not the spot where you leave it when its running but the spot that makes the engine turn over my wipers start working. I tried unplugging my multifunction switch and they still run when I do this. When the wipers are not running and I try to put a fuse in the spot for wipers it instantly pops. I really need to fix this any help would be appreciated!
95-F-2FITTY
arkansas
Is that swap suspose to be plug and play or is a automatic pinned out different in the firewall 76 pin connector?
Gary
South Lyon Mi
Check to make sure you connected the ground wire behind the kick panel by the E-brake, been there before.
