Need some help huge amount coolant gone.
Mcdonald22
Alright just found out ******* is no more and led me here hopefully some one can help.
I have a 08 f-250 234k miles with ******* it lives on 210 tow tune that all i do is pull stuff standard *** ****** an intake noting else, replaced water pump 2 months ago old one finally gave out new degas cap 2 months ago as well.
So I just made a trip 1,200 miles from Texas to Tennessee unloaded not pulling anything 70-80 mph and on this trip i had to put a total of 7, yes 7 GALLONS of coolant/water mixture in to keep it from overheating. It is not leaking anywhere under the truck running or not running i have laid under it and looked/stared deeply also i cant say that i notice it smoking when i tried to look mainly (watching the road), and its not flowing out the tail pipe and its not going into the oil ( i checked several times ) so where did 7 gallons of fluid go?
#1 everyone jumps to blown head gaskets yes its possible ( but i honestly baby this thing its my pull rig an make my living with it so im careful keep my boost max 40 psi and it stays on 210 tow )
#2 I never got around to doing the EGR ****** just had them closed with the tune so could one have busted inside and is passing coolant into motor and getting burnt in cylinder? this is what im leaning on and guessing but want other opinions
It starts and drives just fine like nothing is wrong until after about 400 miles it starts to heat up 198-208 temp i check coolant and it needs like 2 gallons.
likely head gaskets but could be a cracked egr cooler as well. normally speaking if the egr cooler cracks, it fills the back cylinder on the drivers side with coolant causing a hydrolock...when the truck is not running.
Is there any dried coolant around the degas bottle cap or sprayed on the firewall behind the turbos?
Mcdonald22
Sorry for late update life got in the way but for anyone checking this post out it was found to be a combination of a very small pin hole in the freeze plug of the water pump and a leaking 0-ring on upper radiator hose can not figure out why there was no leaking under the truck possibly just blew away while driving 4-5 hrs at a time
