Powerstroked6.7
I'm putting a 15' cp4 in my 11', dose anyone know the procedure for changing it out
What is that the high pressure pump? I may be able to get you the ford procedure
Sent from my Nexus 6 using Tapatalk
Try thisYes it's the HP pump.
I put the PDF file up. It came straight from the ford shop manual. I would trust that over all data...I'll check alldata out
I agree.
Its a pretty easy deal, making sure the timing is right on the pump is the worse part. And setting up the puller on the first one you do. After that its cake
