Piston protrusion issue
B.C Canada
Hey,
I'm rebuilding my 04 6.0 and come to a little speed bump.
I had the head and block machined and I've got the pistons in now but they have a .040 protrusion above the block. Now I also have a stage 2 cam with more lift which could add to the problem. The thing I'm wondering about is If my fly cut pistons will clearance this or if I need to have them machined, the kit is a stage 2 dynamic diesel rebuild.
Any help is appreciated
Extended Power
If it were me, I'd get 0.010" or even 0.015" cut from each piston top, and have them de-lipped.
Makes less compression, but since you are planning compounds, it's a good idea.
B.C Canada
They are delipped but I I guess to be safe it would be a good idea to take some off.
Unless anyone has other experience with piston protrusion
B.C Canada
I took some more measurements and the fly cuts are .010 below the block and the rest of the piston is .040 above. If the valve reliefs are below the block, will this still be a problem?
B.C Canada
Ok, I contacted dynamic diesel and they got back to me right away, assuring me that with the valve pockets it would be fine even with the stage 2 cam. The gasket is about 0.052 this so the .040 piston protrusion is fine!
Big relief.
TRUBBS
Balls Deep
I would be careful, if it was me I would machine the tops while it’s out.
I just finished putting a 6.4 back together that had a dynamic rebuild installed and had .040 Protrusion. Ended up kissing every valve. Granted it was a Stage 1 cam, Non flycut pistons.
Spec calls for .024-.034 of protrusion, weather they say it’s “fine” or not, you’re still out of spec.
B.C Canada
Ya but if you got a .053 head gasket and a .050 fly cut, there is no way you'll nick a valve. Idk just my thoughts. I'll check it when I got the heads on with an old gasket.
