Utility/service body
Looking to replace the bed from my 97 f250 with a utility body from a 86 f250. Other than not being able to use both fuel tanks, does anyone know what other issues I may run into?
Strokersace
Towanda, KS
An 86 f250 also had dual tanks so I’m not sure why you couldn’t use them like normal?
Frames should be the exact same from a bed mount standpoint so should bolt right up. If the bed has a wire adapter to plug into the 86 harness, that will likely be a different plug than the 97 but not sure.
