Ficm and ecm
Strokinn6.0
New jersey
Can I switch to a php ficm tuner if I already tuned my ficm with the innovative ficm tuner. And am I gaining anything by switching to php . I run innovatives inductive heating tunes
6.0xcursion
You should be able to load it right on. When you set the php to stock it puts the innovative diesel flash you had back on. Depending on the tune you install you can see a difference, I dont think they recommend a high power ficm flash with a high power ecm flash tho so running a lower flash you may not see a difference.
