Front axle shaft help!!!!
CoastalF350
Changing my ball joints and got it then installed. I am stumped on the end of the shaft. Any ideas to get this seal to sit flush ImageUploadedByTapatalk1418870766.093121.jpgImageUploadedByTapatalk1418870781.694740.jpg
webb06
Seneca, MO
It doesn't need to. As long as the inner metal is flat against the flat spot on the shaft you're good to go.
CoastalF350
I have everything installed... Now the mutha freaking steering wheel wont return back to center and it wonders everywhere...
CoastalF350
I tourqed the tie rods to specks on the end and measured my Old rod to get the right measurement ImageUploadedByTapatalk1418948292.150853.jpg
psduser1
on the road
I don't comprehend what you are saying, sorry.
Sorry, long day yesterday. Measure from center of the tierod end to center of tierod end. When you change the end, remeasure, and make the number the same. Should be able to get them within a sixteenth, makes it drivable to get an alignment.
Not all ends are the same, especially replacement ends. If you measure the total length, you'll generally end up much closer. Using the center of the grease zero is fairly close.
At this point, might as well drive it to a shop for an alignment, lol.
And, as gary pointed out, the seal tool makes life a lot easier to set the proper depth on the seal. $40, I think I paid. Worth it.
