Stalling problem
Max_Mowry
Hi guys, new to the forum, not sure if I'm in the right category, but I could really use some help.
For the past 5 or so months, I haven't been able to drive my truck. It's a 1997 7.3 powerstroke. The problem seems to come either once the truck has warm and is moving at any speed, any direction, or going up hills. The truck stalls out and has a check engine light. I can flip the key off and back on and the cel is off, but the truck won't start until the next day.
I've got new glow plugs, plug relay, fuel filter icp, cam sensor, icp, ipr ebpv sensor. I have new fuel lines and sending unit in the tank. My valve cover gaskets are also in good shape, so I have no clue what's wrong....anything helps, thanks
Also my truck is all stock, with 283,xxx miles with an automatic transmission
79jasper
skiatook, Oklahoma
What brand sensors did you get?
You say next day, but will it restart after a few hours?
Sounding HPO related. Could be worn out hpop also n
Sent from my SM-T537R4 using Tapatalk
