Water pump/front cover?
vcassens
Godfrey,il
I am in the process of replacing my water pump and this is what i found when i took it off. Will i be okay to put a new pump in like it is? Or should i be looking into a new front cover?
psduser1
on the road
If the engine is in the truck, I'd run it. If the engine is on the stand, I'd change it.:thumbsup:
DEEZUZ
NO PUKESTERS
NWI
There are no decent used ones... When they were on back order customers were bringing us a few used ones and we told them we would not install them.
As far as back order, that should be fulfilled by now. We ordered 6 in Nov, just got em in in January
psduser1
on the road
Guess I'm lucky
vcassens
Godfrey,il
Well got an oil sample back and there is allot of bearing material in the oil also so i said screw it and put a pump on and I'm going to run it until it dies and start building a motor for it
powerstroker67
We do have a couple new OEM 5C3Z-6608-B front cover kits currently in stock if someone needs one. This is the 2005 and up style cover withthe lower hose outlet at the 3 oclock position, but can be used on 2003-2004 trucks with the corect water pump(03) and lower hose
