WILD_PHIL
East TX
Rebuilding the front end. Piecing parts together to avoid getting phucked. Lol
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
ToMang07
Mainah!
Did the entire rear brakes replacement with Powerstop D/S Rotors, calipers, performance ceramic pads, brackets and hardware. Also had to tear the front end apart to replace both front disc brake "dust" shields, royal pain in the arse on a rusty truck. Ended up replacing both ABS sensors since they got destroyed when I removed them. Used that time to use the riffraff tool to lube the hubs tho.
Powerstroke214
Baton Rouge, LA
Gonna try to quiet it down…
Taking it to a muffler shop to cut and reweld the hanger(it's off a 6.4 and doesn't fit)
Leftthenleft
Nc
Trying to finish up the lift. Haven't driven the thing since June. :cursing:
7.3powerstroke00
Brownwood
Thanks, he's about 8 months old and he's a turd! Been to work with me everyday since I got him at 5 weeks.
sent from the best place on earth! TEXAS!
Had a total of 3 rims get hairline cracks. Had them warrantied and went with more black(all they had locally)
SDS97_7.3
Finksburg, Maryland
Not today, but recently did rear pads, rotors, and dust shields on mine. And still want to punch whoever in the face that thought it was a great idea to have to remove axles, to replace dust shields
ToMang07
Mainah!
It's ***king stupid all the work you have to do to replace those chinzy shields. I just did my front ones...2 abs sensors later.
Sent from the pocket porn device.
SDS97_7.3
Finksburg, Maryland
Yup, didn't even know they were rusted until I pulled everything off. But why the hell should you have to pull the rear axles to replace that little piece of stamped metal
duddy
sloshkosh wi
Snapped the rear axle pinion off, kinda wild ride on the street. I'm ok. Truck is good needs a new axle tho.
duddy
sloshkosh wi
Trying to find a vibration. Took for a short ride with different rims and tires. Glad no one else was involved. I'm assuming I had the shaft partially twisted. The bad part, I went on a 180 mile run doing 80 to 90 down a 4 lane on Wednesday. The only thing I could think was that could of been a lot worse.
