The Baddest Bypass Filtration You Can Imagine
psduser1
on the road
After testing on my truck is finished ill need a stock truck to test fit. My truck is far from stock when it comes to the oil.
Mine are stock:lookaround:
Oh yeah, they never get abused, either. Promise.
jimdawg185
I am building the kit right now for testing. Id love to test against the fs2500. That's probably the most popular kit on the market right now. Let me finish the tests on my truck first though. Also, anyone have an idea about a return that doesn't go into the cap for a cleaner install?
campbellflage
Hudson, FL
Still clean this way in my opinion.
SEABEE08FX4
Montgomery TX
Honestly that's going to be your easiest universal way of doing it, may not be the most cosmetically clean way. But beyond that will require modifications that may be beyond your average consumer or beyond what they are willing to do to run the kit.
jimdawg185
I was thinking about having both options available. I really don't like all the hoses on top of the engine like that, but im a perfectionist.
SEABEE08FX4
Montgomery TX
I don't either personally, but you have to look at it from a consumer point of view. And figure in whats least intimidating for them to take skill level wise and permanent modification wise. Short of having a machined fitting for each motor that you plan on marketing a kit for, or supplying the necessary fittings to have the end user make a modification that is. Both of which I think would limit your sales.
79jasper
skiatook, Oklahoma
A option for 7.3's would be like the amsoil kit where you punch a hole in the oil pan and screw in a fitting.
The fitting itself is BP40.
psduser1
on the road
Something like this.
What size is your return line? Text if you prefer, jim.
rusty1161
Whittier, CA
What about the 3/8" plug just above the oil cooler/filter mount?
Rusty
Illinois
I'm with you Jim. Need something better than hoses everywhere. Could a fitting or plate be added to the base of the oil-fill canister?
I tried adding some pictures of the elite CCV ******. Looks like there might be some options there.
jimdawg185
The 3/8 plug is an option for pressure, but ive heard that sone replacement covers don't have it. So thats why I was thinking of getting a tee for the pressure sensor. The return is a little trickier, there really isn't an easy place to do it on a 6.4. The 6.0 might have a place on one of the valve covers.
CyrusLoewen
Glenn CA
It might be a little late to change anything but could you ad a heater to the system somehow. Just thinking for guys in the cold areas with 5 gallons of cold oil to warm up.... Might be pointless Idk just a suggestion.
Sent from my 0PAJ5 using Tapatalk
rusty1161
Whittier, CA
It's not on the oil cooler, it's above it on the block itself. I believe Oilguard uses that spot for a return.
Rusty
jimdawg185
Oops, I was thinking 6.0/6.4. The 7.3 is pretty easy. I apologize
jimdawg185
With my front mount oil cooler, I need all the oil heater I can get. But that's just me.
