Towing with a slide-in camper
DZL JIM
North East Ohio
What do you guys use to extend the truck's hitch when you have a slide-in camper in the bed of the truck that hangs over the back?
Interested in what's needed to do this and pull a box trailer with a car inside.
Thanks.
Halestorm55
Skiatook, OK
We have a slide in hitch extender thats like 4' long and added a 3/8 piece of bar stock that goes into the ball mount in the bumper for extra support. I'll take a picture when I get home if I can remember. I have no idea what brand it is though.
big adam
Lafayette, La
I am also interested in this. I just picked this unit up pretty cheap. I need to add airbags. . uploadfromtaptalk1448402100255.jpg
Sent from my SAMSUNG-SM-N910A using Tapatalk
bluedge8
Champlin MN
As stated above, Super hitch is the way to go. Expensive as hell, but worth it. The hitch I bought is rated at 600lbs tongue weight, 6000 lbs towing- no load equalizing at 36" extension. with load equalizing goes up to 12,000 lbs.
DZL JIM
North East Ohio
Thanks for the info. I did some research and I'm not very comfortable with what's out there. I'd probably build my own hitch with custom rear bumper just to make sure it's all strong enogh. I was hoping to see what others came up with along those lines.
Zmann
2006.1f250
DFW
I built my own also it has 4 hitch points and a 40"double beam extension
picture is a single bar test fit before the modification
I also built my own tie down anchors for my camper
removable like a torklift but strong enough to lift the truck from
when in doubt bust the welder out ;-)
but the Superhitch Magnum is what I would have done if money was no issue and I was towing heavy
http://www.torklift.com/index.php/products/towing/superhitch-receiver-hitches/superhitch-magnum-30k
Nice Fox! I have a 990.
Halestorm55
Skiatook, OK
Sorry I took so long finally found the dang thing.
Looks like a production model
Bottom bar to truck is solid 2"
96 model lance camper hangs over about 4'
1/2" flat stock mounts to bumper in forward hole
Works really well and could easily be made.
