Got the stock turbo off and today's the big install day. Big thanks to all the guys who have reached out and helped and gave me great info along the way. Build is as follows.
S369sxe .91 divided t4
hd up pipes with 100 psi bellows
metal custom ic pipes
100 psi burst rated boots
340 150 hybrids
First set of 6 0 electric dual hpops
58 volt ficm
twisted stage 4 with pi convertor 2200 rpm stall
Erics tunes
Rcd rods
.030 over pistons
Pistons were machined, ceramic coated bowls with the edge lips removed , teflon coating skirts, cry treated pistons , final compression around 15.5:1, broken in with 3 k miles on it with a stock turbo being nice
dsp crank case vent eliminated
PSE regulated return with an a1000 and rudys sump
Brand new heads, rcd push rods, Hamilton springs
custom pedestal , feed and drain lines by dsp jb
will only be pushing it on fuel only
hp predictions ????
Thanks to all who have helped!!!!very excited
340 150 hybrids
58 volt ficm
Erics tunes
Rcd rods
.030 over pistons
hp predictions ????
