question/tips/tricks/advice/how to thread
Warmed up and it's back to normal. Not sure what the deal is.
I'll remove some of the extra coolant and watch it for a few days. I'm sure I'll end up being a new hose soon though.
so its pulling it out as it cools off?
redneck1
Nor Cal
keep track and if it does prove to work out, maybe you could do a lil write up on it for our site..
I'll keep tabs on it. I'll keep track of my brothers truck also. But that's why I wanted someone else to try it, because it works for me but I'd like some other people to try it. I'll run it for awhile and give some feedback maybe do a write-up. It's so simple i can't believe it works.
Beyond the edge of reason
perfect
has anyone experienced random blinking headlights? noticed it a couple times now that out of the blue my headlights will flash when its parked, engine off, and keys out of the ignition.. WTF over?
Do you have a security system? Maybe something is partially alerting it. A loud noise or something.
i have whatever came on it from ford.. i think its just the basic doors locked and horn flashes if doors are open without hitting the unlock button type thing.. it was dead quiet when i stood beside it and it flashed...
dsberman94
Pennsylvania
Idk. I thought I've seen them do it before but then I thought I was just seeing things too. Weird for sure.
OutlawII
Maybe its not really a truck maybe its a Transformer!!!!! LOLLOL
But seriously i've never seen mine do this maybe you need to get her to the doctor
hasn't done it since that day from what i can tell anyway.. ***in technology.... its all electronic bullchit that can get crossed up...
Strokin&Smokin
Louisiana
Can anyone explain a loud whining noise coming from the area where the second fuel filter is located under the hood when the truck is low on diesel?
Started it up Friday for the first time in a week had about 13 miles till empty and it whined its ass off until I drove to the station and filled up. It stopped after about 3-4 gallons got pumped in.
Never has done it before and hasn't done it since.
Also before I left the house after I heard the whine I tried to drain the separator and it barely dripped out. Was it just that low on diesel?
Sent from my iPhone 5s using Tapatalk
it is due to the fact that only a moron would let fuel get lower than a quarter of a tank in a truck with a $16k fuel system and starts sucking air. starve that hpfp and you will send shrapnel through your entire fuel system..
but, a lot of guys have that whine at idle all the time regardless of fuel level .. i dont. but a few have reported and made a thread about it on here.. in your case, you where on the verge of destroying your hpfp... the others that do it, have no idea what it is..
Strokin&Smokin
Louisiana
Well thanks jake I always like getting called stupid for allowing something to happen where it is the first time hearing the consequences.
One day I may be as knowledgable as you when it comes to diesels. Until then stupid is as stupid does.
lol.. you know im ***in with you and gave you the explanation all at once.. its way to easy to just say that its from running the fuel to low.. what fun is that?
Strokin&Smokin
Louisiana
You wouldn't be jake from State Farm in that case. I still love you in khakis.
lol.. you have no idea how many times a week i hear that! not the khakis though.. thats only for you lil fella..
Strokin&Smokin
Louisiana
I think I was one of the first but I can't find the text from 2014 when I changed your name in my phone
