- Joined
- Oct 3, 2012
- Messages
- 11,842
- Reaction score
- 32
Have you changed tunes at all?
If you give it more throttle will it come out of it?
So even with a single pump and stock injectors it still does it? Is it bypassing inside the pump or returning out the injectors through the heads?
Has the pump been reversed on the front mounted pump?
Just a recap. The truck is back to stock fuel,
with a new rail pressure sensor, hpfp gasket/harness.
Also has a hpfp, and injectors pulled from a running truck.
Did you try new under vc harness on rail sensor side?
Have you changed the pump harness and any wiring that may control the pump?
I guess my next question would be what sensors are utilized to increase PW, that may be freaking out?
Crazy out in left field thought, but figure id throw it out there as the uvc harness has been recommended, but are your ebp and map sensors reading roght? Could be it starys to dump fuel trying to increase ebp or map. Also, does low pressure stay steady? Maybe somethin floating in the tank and plugs the pick up, or a kinked line or something, rsstricting flow either to the low pressure pump or to the hi pressure pump...
No luck yet, but I did manage to get a vid.
Shows exactly what I'm dealing with.
Truck is running without turbos is why it sounds so... awsome!
https://youtu.be/9kIXAayUZlc
Thats Crazy.
I'm gonna go after the actual engine harness next.
Gonna figure it out one way or another.
