- Joined
- Oct 3, 2012
- Messages
- 11,855
- Reaction score
- 32
Yes you can mix and match rods.
How hard is it to port and polish these cylinder heads on your own, In your garage, with die grinders and what not? And would it be worth it
It was just a thought haha. I been watching engine masters on YouTube and it had me thinking about porting my heads lol
You cant even compare that to diesel heads. Especially 6.4 heads haha
I have 2 blocks a k16 pump and bunch other 6.4 parts I also have 6.0 manis if ur interested let me know
So I'm thinking of going a different direction with my build. I'm thinking of keeping the compounds, I actually got my hands on a internally waste gated turbo off a Cummins QSX15. Measurements are 84mm compressor with a .69 AR and the exhaust is a 107mm with a 1.19 AR. My question is will this turbo be a good turbo to run for a low pressure charger? And if so what would be a good pairing for a high pressure turbo
yeah it could be decent at best , but it certainly would not be optimum. it will most likely be a cast wheel, slow spooling , journal bearing charger with a massive turbine wheel. if used with a vgt high pressure it could be okay at best. cummins designed turbo's use WAY bigger turbine sizes than any V8 common rail diesel in a light duty pickup. there's a reason most big twin kits stick to much smaller turbine wheels , and the crap head flow of a 6.4 only expose those issues more. i , personally , even not knowing the EXACT basics of that turbo , i wouldn't ever put it on a 6.4 , or even a 6.7 with much better headflow.
