AKF250 Alaska Build - (650-700HP BUILD)
akf250
Headlights
What about using 2017 headlights?
Any design change from 2008?
Jsexton
Alabama
Tail lights...
I have those tail lights to my truck they were paint match from retro customs they are awsome and look good at night
akf250
Looking for advice on injectors. Injectors have 100,000 miles on them and have carbon build up around the tips. Had no signs of any issues with injectors.
Is it ok to just scrub the tips with a scotch brite to clean them up? Should I just get new tips put in?
Roccafellas
I’d send them out to GCL Diesel or any Reputable test centre have them flow tested to make sure there prepared to stand the test of time of mounds of power that your about to throw at it. $52 and thats CAD bucks a piece.. decent shipping and If you ask for Colin at GCL in Fuel Injection services. I’m sure he’ll give you the same deal he gave me if you test all 8. and throw in the Fuel Additive 945ml bottle for free.
I thought mine were good. The piezo crystal itself (the actuator) were bad in 2 and the flow test failed on 2.. by minor specs but would only get worse..
if there fine, they also clean them and ship them back with brand new orings around the pintle. Free of charge.. which you might want to do as well as the upper oring as well.. replace.
Just a thought.
Crack85
Midland, Tx
Have rcd test, flow and balance them.
Sent from my Pixel XL using Tapatalk
akf250
Sweet, thanks guys!
Still in the air about 15% nozzles. I am putting a brand new LP and HP fuel system into the truck and have been speaking to B585Ford about his experience with the mild nozzle upgrade.
"GH did the tunes. I use a MM. I have not put that many miles on since doing the injectors (about 20k Miles). I have not had any problems since installing them. You see a noticeable improvement in spool up, but it does get warmer during acceleration."
I have a *******. Does Patriot Diagnostics do custom tuning? If I was gonna work with anyone for custom tuning should I use a specific company or tuner? Does the type of tuner really matter? Could one company send you a file for a different tuner or is it all tuner specific?
I'd love to live tune it of course but that won't be able to happen in Alaska
akf250
Progress Post
FASS 150 GPH Low Pressure Pump Installed
External Filter Kit Installed
Sorry about the images being all flipped around. No matter what I do they keep flipping around.
Had to use a angle grinder to get the old tips off, they were stuck! Cleaned up the tailpipe with a angle grinder, got new MBRP tips in. Gotta shorten the tailpipe a little to get the look just right.
akf250
Progress Post - Cam
Got the cam out. Made the rookie mistake of not unbolting the torque converter and pulling it with the transmission. I don't think I would have been able to get the nuts off from that little hole anyways.
Gonna do new motor mounts, flywheel, and starter while I'm here.
Still waiting for the cam, UPS guy forgot one package when he picked up all my stuff from the shop.
Got my new coolant tank, RCD manifolds, and O-Ringed heads in.
ckrueg
Belding MI
Sweet, thanks guys!
I believe they are working on finishing on screen tuning for the 6.7s before they will do custom tunes. However, they have OST for 6.4s and it does allow for adjusting for injectors, turbo, etc. I would recommend trying that out, and then if you don't like it go from there
akf250
True Trac
Is this the correct part number for the Detroit True Trac for a F250?
I don't have the utmost trust from my local driveline shop, they tried to sell me a air locker.
Eaton Detroit Truetrac Differentials TT70P52595
Summit Racing Part Number:DTL-915A550
akf250
Injectors + Progress
Sent my injectors off to Oregon Injection yesterday to get tested and cleaned up. Just gonna keep it simple and keep stock injectors. Sounds like the benefits are just not proven and the tuning would be a hassle.
Replaced my motor mounts, sawzall'd all my cab insulators off, and got the first round of head stud hole cleaning done.
Bought a set of OUO Adjustable Link Arms.
Looking at lifting the motor once more, pulling the oil pan and welding in a bung for a oil heat exchanger for my Webasto system while I'm only 2 quick bolts away.
This truck will have 3+ months a year in negative 20 or colder temps and I want everything to have the hydronic heater running through it.
Coolant, LPFP, Oil Pan, and potentially some lines running around one of the batteries will be connected to the Webasto/Espar.
Check this heat exchanger out
http://www.partssystems.com/mini-heat-exchanger.html
akf250
Not Yet
Not up and running yet, I've been away from the build for over a month traveling through Canada. Just dusted her off today and started on some small things tonight.
- Started grinding and cleaning the rust off the top of the shock towers so I can get them resealed.
- FINALLY! got my new cam in the mail and got the gear pressed on. Now just waiting for my push rods to show up.
- Got my OUO 3 Link Setup in and they look awesome!
- Got the handle relocation plate welded in on my tailgate, just gotta drop it off at the body shop now.
- Got the last box of intake sensors, replaced the cam and crank sensors.
- Pulled the trigger on a Mag-Hytec Oil Pan to gain those extra 8 quarts, and a Red Head Steering Box while I'm here.
The test and tune date has now been set! Time to push it! :ford:
June 23rd - Prowl for Power - 907 Diesel Day
http://www.raceak.com/profile/?r=236223&rt=sch
akf250
Painting
Painting & Parts
