Tag on rear different '83 F-250 3/4 ton 2wd..
mikelashbaugh2
Hows it goin haven't posted here but glad to find some people that could maybe help me out....
I have a 1983 f-250 3/4 ton 2wd , ive looked around the yards around my area and there's a bunch of 3/4 tons around same year but every one I find is different than mine. I thought my Spyder gears had **** out on me but when I cracked the cover oddly enough gears are fine no damage same as ring and pinion but the pin was in pieces don't know how or why everything else is all good but how can I know where or or tell any parts house what part # or which is the correct to order. Since all the gears are good I'd rather not buy the set. I have the tag but dont really know what it means . If anyone out there could help me out I'd appreciate it
mikelashbaugh2
3.07 gears.
I think that's a Dana 60 semi floater.
Sent from my SM-G892A using Tapatalk
I was told that my truck was a full floating rear axel by Les Schwab and they had to pull the Axel's when I was re doing my brakes does that change anything ..
TD-5
British Columbia Canada
The # 605040-7 is the bill of material number & identifies it. I can't find a part number just for the pinion gears carrier pin but with the attached info if you contact Randy's ring & pinion or any gear shop they should be able to find it. If the pin bore in the carrier case is worn at all, then its junk. & a new pin won't help.
https://www.ringpinion.com/
TD-5
From the Randy's web site; This should be what you need, but better to call & confirm.
