Tips to loosen fan?
Well, I tried the air hammer thing and got a bunch of impact marks in the nut. I worry that there’s just way too much rust in there. The pulley directly below has a bunch or rust, and the undercarriage has a ton of rust. I’ve also tried a crescent wrench and a sledge hammer. Nothing seems to break it loose so far. I haven’t ordered the wrench set from Amazon linked above since it’s over $100...does the air hammer and chisel normally tear up the edge like that? Or does it usually give and turn before then?
Should I be looking to see if something else is broken on the assembly?
Oh hell.... give her way more than that!
Like the other guys have said..
dieselappnerd
Yeah, the answer was just hit it more with the air hammer. I did and it came right off real smooth. Thanks.
m j
BC Canada Eh!
its an 1 7/8" wrench and a bar to hold the pulley.
took me 2 secs to loosen.
the pic of the OP with his no leverage tiny wrenches is the issue..
