'11-14' Retro Fit or Upgrade?
jimmystoys
Surrey, BC
Hi all. Searched some retro fits and upgrades from the past here but it's been kinda quite so thought to bring it up and see if any ones done anything lately that they're satisfied with. Not looking for a drag racer just want to replace/upgrade my '12 (I think I'm on borrowed time with it 212k lol) with something that's reliable. I have an old S****** file. If this is not a 'chatty' topic anymore, just pm me, thanks.
erbear28
Pennsylvania
Stock 15+ turbo would be your best bet if you plan on leaving the hpfp alone
farm boy
Rosharon, TX
Wicked
Fairhope, AL
BD just released a new drop in Turbo. It has larger wheels on it but unsure the blade count on the turbine. Might be a good option.
HeavyAssault
Middle, VA
So I can share info with others.
What is used for the tuning files?? Are they straight OEM files tweaked to use on 11-14 trucks?? Are they "custom" tweaked PCM/TCM files short of being full ****** files???
I tend to suggest to 11-14 people to go with the 2015+ hardware upgrade but rarely hear about that it takes on the tuning side.
joebuck
Yes with Tyrant tuning which is who I run they fuel a little heavier down low to get the larger 15+ turbo to light off quicker. It’s not Smokey unless you flat foot it it’s just the way fueling works to keep it less “laggy” from what I understand.
jimmystoys
Surrey, BC
Was wondering if I need to upgrade the HPFP? Your suggesting it's not needed? Probably a good idea to do. I think that's been upgraded too on the 2015's? Or maybe aftermarket HPFP puts out more fuel? Maybe someone can clarify that for me.
jimmystoys
Surrey, BC
I've been happy with my stock 17' turbo and HPFP upgrade. Although now I think I would have tried the new cheetah turbo that's out there just for the hell of it.
http://nolimitfabrication.com/index.php?route=product/product&path=138_74&product_id=674
Truck pulls awesome though and has plenty of power for a work truck.
Drags a 20 bale hay van like it was made for it.
So farmboy you have a '17 turbo on your '13, if i read that correctly. Swap went ok? And what brand of HPFP did you install? I looked at that No Limit turbo. Looks pretty good too mind you it's pushin up to 45psi. Might have to worry about that on a stock set up?
erbear28
Pennsylvania
2015+ hpfp flows more than the 11-14. The 15 turbo by itself on a 11-14 is fine but if your truck has some miles on it it wouldn’t be a bad idea to upgrade to the 15+ pump.
jimmystoys
Surrey, BC
So in my situation I'm running the old S****** tuner with full d*****. Just what we did back then. I am happy with it. It's been good to me. But I think it could be complicated should I need to tweek 'it'.
jimmystoys
Surrey, BC
Ya probably upgrading would be a good idea once I've committed myself. So should a 2015 and up stock hpfp be used or after market? Can I benefit from more fuel from aftermarket pump?
erbear28
Pennsylvania
Basically your only aftermarket option is a stroker pump but iirc they don’t last as long as a stock 15+ pump but you wouldn’t benefit from a stroker pump on a stock 15+ turbo
Powerstroke214
Baton Rouge, LA
You may not NEED a revision, but you may benefit from it. I had Patriot OST on my 14 and LOVED it, allowed for the tweaking I needed, in your situation without OST you'll need to get a new device.
jimmystoys
Surrey, BC
That would suck if I needed a new device. Quite happy with what I have now. I would hate to do a complete turbo upgrade and struggle with figuring out what or who's tuner to go with. Don't like unprepared changes. Trying to get all my ducks in a row...
farm boy
Rosharon, TX
Yes 17' turbo on the 13'. Swap was done by Powerstroke Enginuities in Houston.
I went with a Factory 2015+ HPFP since I'm not running bigger injectors.
