new truck
MAC
Richmond, IN
The mechanical ones work fine, not knocking them at all, just throwing other options out there.
2006nytro
Bellevue mi
Ok cool hope this fixes my problems. If not I'll go kidnap kitty cat
:) with some catnip and 100$ bills lol should work.haha
MAC
Richmond, IN
Well anything can happen, just depends on how old the pump is.
Push the schrader valve on the fuel filter head and crank the engine to see if you're getting any fuel to the fuel filter, if you are then loosen one injector line at a time and crank the engine and see if you're getting fuel to the injectors, doing this will also work out any air that might be in the system.
If you're not getting fuel to the injectors, but you are getting fuel the the IP I would say the pump gave out.
If you are getting fuel to the IP and you are also getting fuel to the injectors I would say you have huge air leak somewhere.
In that case my guess would be the return lines, or it could also be the old fuel water separator mounted on the drivers side fire wall (silver fuel filter looking thing) if it is still hooked up.
MAC
Richmond, IN
Check and see if this thing is still hooked up on the drivers side firewall.
MAC
Richmond, IN
Yes, it's known for letting huge amounts of air in the fuel system.
To make sure that is the problem before buying all the stuff to get rid of it, just try bypassing it for now and see what happens.
MAC
Richmond, IN
Yep, happens all the time.
If that was the case it would need at least 1/4 tank full to get any fuel.
How full is your tank?
2006nytro
Bellevue mi
Ok I found out the fuel pump isn't hiting the crank the one I took out and the aftermarket one the rod that drives it are different. So I ordered one from ford so we will see if that ones different
