04 f250 6.0 $5500
Decker
Michigan
2004 Ford F250
208000miles
This truck is no show truck. Would be decent work truck or someone toy.
Truck did sit for a year while I was deployed. After few cranks she fired right up and does run. Just want give as much info as I can.
Anyways truck has
- 4 in lift
- 35in tires 315/85r16
- Mastercraft MXT w/ great tread on 16x10 alloy wheels with balancing beads
- egr ******d
- NOT studded but will come with ARP studs
- blue spring upgrade
- coolant filter
- running rotella ultra elc coolant
- Dual steering stabilizers
- Stock dp with 4 in exhaust with 5 in stacks
- 4 pod pillar guage (fuel pressure, pyro,trans,boost)
- arb winch bumper with bush guard welded to front
- 1/4 steel rear bumper
- mile marker locking hubs
Interior has no rips back seat has a few stains
Trans shifts firm and strong
Cluster is in kph truck came from canada when I baught it. Can still read mph under kph
Extras coming with truck
- ARP studs
- tan running board
- black running boards
Bad
Needs wheel bearing passenger side
Bed rusted
Cab corners rusted
Coolant filter hose need be replace mouse got to it.
$5500
Not interested in trades
Decker
Michigan
Truck started having hot no starts, which turn into hot/cold no start.
She cranks, wants to turn over but never does.
Don't have time to fix at the moment.
Price drop 3500
KBMKVIII
Texas
If you need some help diagnosing, I am near the Brighton area.
I have AE software for diagnostics.
Decker
Michigan
I appreciate it. I might take you up on that when it gets little warmer. I have some local interest as how it sits now. But if it doesn't sell I'll shoot you a pm
