05 axle coil swap
mawbuilds
Having a issue with the track bar hitting engine crossmember. Has anyone else ran into this problem. I have 95 f250. I didn't add a lift or leveling kit when I did the swap.
CJunkie
'Murica
Are you using a Trac bar bracket intended for the 05 axle swaps?
Sent from my LM-V350 using Tapatalk
Addicted4
Post up a picture and details of your swap. Year of axles and are you using a kit or factory suspension parts
mawbuilds
All factory parts. 05-07 parts. Rough country adjustable track bar. Have a ballastic fab universal weld on mount. Also have a ready lift factory style mount 05-07. Also factory mount for 2018. Can get some pics later today.
CJunkie
'Murica
Iirc, last time I did one it was necessary to shave down the lip on the crossmember to get the Trac bar to clear.
mawbuilds
Yeah thats what I was wondering about. If the lip had to be shaved down. Or could I move the bracket out some. But then the bar would be straight either.
Addicted4
You’ll want to use 05-07 track bar bracket not 08 and newer. When I swapped my 95 I had to clearance in the middle of the bracket from hitting the steering box but did not have to touch the crossmember
Strokersace
Towanda, KS
Yep shave it down. That’s all I did and never had a problem. 100% factory 2005 parts.
