buckster
My '08 F250 (job 3) transmission is currently out of commission. I am assuming it needs a rebuild, but thinking of having it towed to a local shop to confirm it isn't just a solenoid. I am in the Houston, Texas area. It has been driving fine lately, but I did have a slight delay when going into reverse for a while now. Finally parked at work yesterday, and it won't go in drive. When in P, it feels like it wants to go in reverse until it hits a stop. When in R N and sometimes D, the truck only moves in reverse. In 1 2 and 3, it'll roll forward a couple inches then seems to hit a stop. A slight pump of the accelerator pedal and it seems to want to go forward, feels as if it is not engaging, but I didn't give it much as I didn't want to make it worse. So I essentially just have reverse. Does this seem like an internal hard part or could it potentially be a solenoid? Fluid level is good and does not smell burnt. I tried re-flashing the tune and cycling the key on/off as some had said that may help unstick a solenoid, but nothing made a difference to how the truck was acting.
Truck has stock transmission and converter. Has approx. 130k miles on it. I rebuilt the engine myself at 110k or so to fix the head gaskets and made several upgrades. Never dyno'd, but probably around 550-600 rwhp. Running IDP tunes since I bought the truck new in '08 (started at 5000 miles), so I don't think it is the tuning.
As I said, truck is currently stuck at my work parking lot. I need to make a decision on where to tow it and get a game plan figured out. If it's potentially just a solenoid, then I may tow it to a dealer or shop that can hopefully scan it and narrow it down to which component. If certain a rebuild is needed, I will probably have to tow it home and start pulling out the transmission myself. Any suggestions would be appreciated. Thanks in advance.
