10" deaver spring ?'s
SaNnDnSurF
SATX
Have an 05 with 12.5" lift looking to get a set of 10" deaver springs for the rear so it will sit level with the front, my question is won't I have to run some type of block to correct pinion angle? Or am I overthinking this one.
Zmann
you really would get it bolted in and check I can send you the spicer PDF on the procedure
Scott over at Deaver is helpful also but I do think you may need a pinion shim on the spring pack
some slip over the locating pin I prefer the bolt on ones
ask Deaver to not clip the center bolt and leave it long so you can take it apart
a little trick is to drill the top plate so the long center bolt can protrude through the plate
